The new Build
It's running pretty much perfectly..it's at a 12.8 through the RPM Range so far, and has no issue really.
I'm going to track it with this tune and see what it does..then I'll look into a Dyno Tune.
Merv,
Good luck with this engine. May you well exceed 120mph.
being vulgar shows your an ignorant bastard this is a technical section
The deck on that block does look horrible, that is also a Lsx engine. This is LTx section..... why is it posted here? What does it offer to the LTx technical section?
I just posted it up cause it was what I was working on..sometimes it's nice to see something different when it's broken down pretty good.
Thank you for the compliment, I'm hoping to see well into the 12X.XX area with this setup.
The deck on that block looks fine to me. Its called reflection of light. But, what would I know, Im only a machinist.
So now you want to take the post another direction and divert away from the block decked with 80 grit sandpaper to cry some more since it would appear you are not getting enough attention? What a hero.
I do. I'd hate to be caught by any one of them. They are ninjas you know!
