Need HElP
Old Oct 16, 2009 | 07:27 PM
97REaper's Avatar
Default Need HElP
Im in the process of getting my 355 together but i want to know what you guys used to remove the timing chain crank sprocket because Im going to use clo-9-3145 timing set.. thanks
Old Oct 16, 2009 | 07:48 PM
AChotrod's Avatar
Did you get the hub off? I just used a 3 jaw puller on the sprocket and kept moving it around to pull it off even.
Old Oct 16, 2009 | 07:51 PM
1slo_camaro's Avatar
From: Born/Raised North East, MD Lived in VA, NC, MI Back in Yorktown, Va
duh a really really big hammer. and chisel. duh!!!!!!!!!!!! lol
Old Oct 16, 2009 | 07:54 PM
litch2004's Avatar
+1 this is the best way to remove it. It will come off with ease using this.
Old Oct 16, 2009 | 08:02 PM
97REaper's Avatar
the short block is assembled i forgot to tell the machine shop to remove the sprocket off.. i used the 3 claw puller to remove the hub.. i just wanted to see if that was the correct way to remove the sprocket..
Old Oct 16, 2009 | 08:06 PM
AChotrod's Avatar
its not the right way to do the hub but works great on the sprocket.
Old Oct 16, 2009 | 08:11 PM
97REaper's Avatar
ok thanks guys
