New Build Questions
http://www.summitracing.com/parts/SCA-26000P/
http://www.summitracing.com/parts/UE...n/?prefilter=1
Piston Material Forged aluminum
Compression Distance (in) 1.265 in.
Piston Head Volume (cc) +6.40cc
Wrist Pin Style Press-fit or floating
Pin Diameter (in) 0.927 in.
Piston Ring Thickness 5/64 in. x 5/64 in. x 3/16 in.
Piston/Pin weight = 487/132g
I am down at sea level right now so that should help out. I am going to see what I can get out of it on motor then start spraying till I get my goal. On my last combo I did a 12.1 pass no nitrous stock heads. So with the new shortblock new cam, stall freshened up tranny and more weight reduction should be pretty good.
If I beams are good enough any one have any suggestions. This is one of the last things I need to get to start my build. Thanks for the help.
