93 z28 MAP sensor
Old Oct 18, 2009 | 05:52 PM
thebeast93's Avatar
Default 93 z28 MAP sensor
How to change it and anything I should know about changing it?
Old Oct 18, 2009 | 06:24 PM
Black96transam's Avatar
(2) 8mm bolts and pull it up.. there is a rubber seal that goes on it.. make sure to put it on the other sensor and when you put the other sensor on push it down good before you tighten it.. dont wanna whop side it..
