Rough idle and dies when I put it into driver or reverse
The Opti was from ebay. Some off brand rebuild. If I knew that the Opti's were problematic when I bought it, I would have bought a GM brand opti. I'll get back to the forum on Monday after installing the O2's.
I'll also check the cam sensor. The car runs great when I drive it. It is just idle RPMS. Would a cam sensor only effect idle?
I've heard a crank sensor will give you similar symptoms, but haven't had any problems with mine yet.
Also when my car went into limp mode from launching to fast on the stock trans tune with a big converter I also got that VSS code but there was nothing actually wrong except for that the computer went into limp mode. This was caused by high engine rpm and a low vss reading making the computer think that the trans was bad/slipping.
http://www.carcraft.com/howto/ls1_en.../photo_09.html
EDIT: Another page to help with location/look..
http://chevythunder.com/ls1_page_1.htm
• New plugs and wires – not burnt or fouled. Wires are in correct order.
• New opti
• New TPS
• Cleaned MAF filament. Unplugging MAF does not change the way the car idles
• No vacuum leaks. Searched by spraying engine start around the engine
I have a solid fuel pressure. I checked while driving and it stayed between 40 and 47 PSI. Double checked Fuel pressure and found 46 PSI at idle and 50 with the vacuum unplugged. Fuel system holds pressure.
• New fuel filter
• No arc’s in wires – checked at night
• Bored out 52mm TB – bought from eBay remanufactured
• No EGR. I have a block off plate
• No Cats
• Rewired and checked park neutral switch
• Checked electrical ground straps
• Changed O2’s to AC Delco
• Lt1pcmtuning base tune – fine tuning coming this week
• Can’t find Cam sensor. I’m pretty sure I do not have one or it might be built into the distributor
Suggestions anyone?
Overlooked that piece of information..
Could be the crank sensor then.. I've heard it has similar symptoms.. It'd probably be easier to check the tune though.. and then if not, go from there.. If it always does it, then I'd say it's in the tune.. If not, sensor..
I wouldn't waste my time with the valves though..
An off brand Ebay opti is a good suspect for problems.
