LT1 Knock
Old Oct 22, 2009 | 12:26 PM
94greenlt1's Avatar
Default LT1 Knock
I drive a 94 z m6 and I have a knock sound coming from the tranny. The car sounds good but the more i rev it, the louder the knock gets. I take my car almost to redline and it feels like the shifter gets stuck. What do you guys think this can be??
Old Oct 22, 2009 | 01:03 PM
sepno77's Avatar
sounds like you better start saving up for a trany rebuild.
Old Oct 22, 2009 | 01:11 PM
rat93's Avatar
yep, that sucks
Old Oct 22, 2009 | 01:27 PM
AChotrod's Avatar
Is it coming from the bellhousing or trans?
Old Oct 22, 2009 | 01:28 PM
old93camaro's Avatar
do you hear a knock or a cluck if a cluck check your bearing in your u joint
Old Oct 22, 2009 | 04:42 PM
94greenlt1's Avatar
I actually just bought this tranny from a friend and it was working on his camaro, it sounds like its coming from the bellhousing i need to double check on that, you can even feel a little vibration on the clutch pedal, but yeah its more of a cluck but hopefully its not something major
Old Oct 22, 2009 | 05:20 PM
LT1's Avatar
LT1
Did you install new pilot bearing? Does the sound happen when its in neutral?
Old Oct 22, 2009 | 06:37 PM
AChotrod's Avatar
did you tighten all the bolts on the clutch and FW to spec?
 Michael S. Palmer
Old Oct 22, 2009 | 11:08 PM
94greenlt1's Avatar
Yeah the clutch kit came with the pilot bearing too, it makes the sound in neutral just not as loud as when your driving or reving it.
Yeah i asked the mechanic if he tightened everything to spec and he said he did. Do you think maybe a cracked bellhousing can cause this??
