lt1 no fire
Old Oct 26, 2009 | 08:48 PM
daville_pits's Avatar
Default lt1 no fire
my buddy has a 1996 trans am and it will just crank and crank and no fire on spark plugs nor coil. any ideas ???? checked with test light and there is power to the coil and he was told the optispark was replaced.. please hit me up with any ideas thanks in advance
Old Oct 27, 2009 | 07:27 AM
jasonisdn's Avatar
http://shbox.com/1/how_tos.html
start testing good luck
Old Oct 27, 2009 | 12:47 PM
rat93's Avatar
well check the plug wires for spark. if the opti is good you know you have spark... then you either have an air/fuel problem
Old Oct 27, 2009 | 02:12 PM
Rob's Avatar
Rob
Check the fuses.
Old Oct 27, 2009 | 02:26 PM
Rick804's Avatar
I would be willing to bet its the ignition control module. Its the little black sensor looking thing right above the coil. Pull the plug and see if one of the prongs inside are bent. I had this happen and it drove me crazy.
Old Oct 27, 2009 | 06:42 PM
ok if the opti spark is bad would the coil still its self put out spark or not???
Old Oct 27, 2009 | 10:50 PM
Rick804's Avatar
Yes it should. Did you check the ICM?
