cam rust
Old Oct 27, 2009 | 03:58 PM
chevyjeff59401's Avatar
Default cam rust
Here's a pic of my cam that got damaged from being installed in a car with no intake and sitting for at least two years in a tow yard. I spoke with a well respected cam man and he is going to attempt to clean it up and make it usable. Any thoughts or advice. Thanks jeff
Old Oct 27, 2009 | 04:00 PM
RamAir95TA's Avatar
As long as the rust is superficial and has not pitted at all, I would be comfortable using it. But if there is ANY pitting whatsoever, that cam is toast.
Old Oct 27, 2009 | 04:01 PM
SS RRR's Avatar
Village Troll
Not necessarily. A machine shop may be able to polish the lobes with no undue harm.
After looking at the pics I would rather take it to a shop and see what they can do.
Old Oct 27, 2009 | 04:05 PM
mdacton's Avatar
Just polish it just like a crank, does not look too bad, have seen worse and they ran fine
Old Oct 27, 2009 | 04:07 PM
Yeah he mentioned me trying to clean it, but i'd much rather have a professional look at it. Just happens to be the guy who originally ground it. So I definetely trust his judgement. Thanks Jeff
Old Oct 27, 2009 | 04:08 PM
derekderek's Avatar
Yea it doesn't look bad. I bet it can be cleaned up.
Old Oct 27, 2009 | 04:09 PM
Funny I thought about chucking it up in my buddies crank grinder and trying to polish it.
Old Oct 27, 2009 | 04:56 PM
sepno77's Avatar
I think if cleaned up good enouph you'll be fine.
Old Oct 27, 2009 | 05:08 PM
ulakovic22's Avatar
Hard to tell, but you can get some 00 steel wool and try to polish it. It also depends on where it's at, lobes and journals can be treated differently.
Old Oct 27, 2009 | 05:30 PM
moderate Z28's Avatar
Even though I oiled it, Mine was like that from sitting over 3 years. I just sanded it with 1000 grit and tossed it in. That doesnt look too bad.
Old Oct 27, 2009 | 05:46 PM
It had assembly lube on it only those four lobes are like that. Four others have tiny specs and none of the journels are damaged at all. Thanks for all your replies
Old Oct 28, 2009 | 01:18 AM
RamAir95TA's Avatar
What I meant was after it had been cleaned. It'd be down right silly to toss that in as-is.
Old Oct 28, 2009 | 07:24 AM
SS RRR's Avatar
Village Troll
Even the pitting can be polished out as long as it's not too deep.
