build question
Old Oct 28, 2009 | 03:24 PM
eagle_eyes's Avatar
Default build question
i haven't been on in a while...the car has been put on the back burner for a while. here's my setup and question:
i have an '88 firebird with a '93 LT1. the transmission is a '90 700R4 built locally. i have an extra set of heads that will be sent to LE for porting. i may redo the bottom end, or at least new bearings, rings, and seals. when it comes time to dyno it, will the '93 ECM (chip) be sufficient, or should i look into converting everything to a later setup that didn't use chips?
Old Oct 28, 2009 | 03:54 PM
the_merv's Avatar
Step it up to a 1995 Setup with a 1995 4L60E..that will help you in the long run to tune it easier.
Old Oct 28, 2009 | 03:59 PM
96capricemgr's Avatar
If you do some digging I believe the 93s with some modification can be setup for real time tuning which might be easier for you than the 94-5 setup which gets reflashed so no realtime tuning.
The stock 93 system is not realtime tuneable I am saying I believe there is a replacement chip you can get that lets you do that. If dyno tuning that could save some serious time.
Old Oct 29, 2009 | 10:20 AM
eagle_eyes's Avatar
thanks for the replys. so 1 vote '95 and 1 vote '93 w/ possible different style chip. i don't plan on retuning the car very often. once it's set on a dyno, i'll leave it alone unless something isn't reading correctly. of coarse, leaving it a '93 would be cheaper, but if the '95 is better, i'd want to look into it. is the '95 an obdI or obdII?
Old Oct 29, 2009 | 10:21 AM
RamAir95TA's Avatar
95 is flashable OBDI, so no burning chips.
Old Oct 29, 2009 | 10:33 AM
But if you go with the reatime tuning on the 93 dyno tuning will be a lot faster and easier.
Both systems have advantages. I put the 94-5 system in my 96 and like it but that does not lead me to automatically think it is the only choice.
