Compression
Old Oct 29, 2009 | 07:53 PM
Z28reggie's Avatar
Default Compression
Ok can someone give me a yea or no on running 12:1 on pump gas Without bad **** happening lol thanks
Old Oct 29, 2009 | 07:54 PM
robsquikz28's Avatar
you will be fine on pumpgas 93 all day but if your spraying then thats a NO
Old Oct 29, 2009 | 08:31 PM
My95Z's Avatar
Depending on your cam you could actually run that on mid grade. You need to focus on the dynamic compression ratio not the static. You only use static as a step to decide what cam to pick or vise versa.
Old Oct 29, 2009 | 09:44 PM
Z28reggie's Avatar
a almost 100% on cc503 wit stock heads and flat top pistons Havent done any math might change pistons to achive 12:1 trying to keep pretty streetable
Old Oct 30, 2009 | 03:36 PM
RamAir95TA's Avatar
Is this pertaining to your magical 500whp project?
You need a much more solid understanding of compression ratio, both dynamic and static, what affects both, and overall how an engine makes its power. Your combo still won't meet your goals.
