Isky Adjustable Guideplates - What joy...
___Next, after finally arriving at what I had to grind off BOTH sides (they intersect so you have to grind some off both the left and right halves) comes the next tedium. First I put some Loctite on the ARP Rocker studs, hand thread the stud into the head, then I carefully orient the halves to align to the tips. Carefully, I lift off the rocker(CC 7/16" Pro Mags) then take the socket and gently place it on the stud and turn it to tighten it to the recommended 50ft lbs. As I turn it, the guideplate is grabbed by the turning stud and pushes off to the right, thus throwing off the alignment. DOH! Repeat two more times to the now thunderous cussing rants. I finally figure out that if I put a bit more amount of hand tightening, then tap it back into place with a brass drift and punch, it'll stay in place for the full tightening.
Hahaha... jeez... good thing I love working on my car/motor.
I will weld mine for THAT reason.
They just arrived...
Huh? Oh.. packing. Never seen this style before...
Now this is more like it...
Pretty....
So I went out to the shop and thought I'd do a quick 'trial' fit using the in-place Iskys. Ugh.. nope. Let me try the stock GM guideplates. Ugh.. nope. Back to the Iskys. Looks like I'll have to do more trimming/grinding on the ISKY's to get them to line up correctly.
