Upgrading MAF. Which one?
Old Nov 3, 2009 | 11:48 AM
Formula383's Avatar
Default Upgrading MAF. Which one?
With the new build I'm pretty sure I'm going to surpass the limits of the stock MAF. I've done some searching but am a little confused on which part number I need.
GM 25341604
-- or --
GM 25318411 which is replaced by 15904068
They both appear to be 85mm but which one should I use?
Old Nov 3, 2009 | 11:51 AM
Tony Shepherd's Avatar
These are Z06 maf's btw
Old Nov 3, 2009 | 11:55 AM
Formula383's Avatar
Yeah, they both have a multitude of applications. I just don't know the differences.
Old Nov 3, 2009 | 12:00 PM
transamsam98's Avatar
just a tip fellas they came on trucks as well and their are several ebay guys selling them for $20 and many places selling adapters for $20-25 shipped.
Old Nov 3, 2009 | 12:41 PM
jasonisdn's Avatar
go to sd and save the money.
Old Nov 3, 2009 | 01:11 PM
LS1 SPEED's Avatar
The 85MM MAF with a stock ECU has less of an operating range the then stock MAF from what I understand. We had nothing but issues with my car above 5K rpm and went back to a stock unit.
though we did make a little more power we could not get the A/F to be accurate
SD would be the way to go, but from what I read it's very time consuming
Old Nov 3, 2009 | 01:31 PM
Kyle.....this might be the way to go.
Old Nov 3, 2009 | 01:37 PM
Formula383's Avatar
Yep, I knew about them being on the trucks too but which part number? Thx.
Old Nov 3, 2009 | 01:39 PM
Formula383's Avatar
That's good info Larry. If I can find one of these $20 ones then maybe I can test it out and revert back if I need to.
Old Nov 3, 2009 | 01:41 PM
the next time im home ill get whatever information i can for you and put it up
Old Nov 3, 2009 | 01:47 PM
Sean had no problems with his nor did I way back when. Should work fine with the correct maf tables.
Old Nov 3, 2009 | 02:09 PM
fergymoto's Avatar
Just get rid of the MAF
Old Nov 3, 2009 | 03:59 PM
Stroked96Bowtie's Avatar
+1 for SD
Wasnt Moe B making 640rwhp with a stock MAF sensor? I think the stock sensor can handle more than folks give it credit for. Just dont go aftermarket. From every tuner Ive talked too, aftermarket MAF sensors are junk and a pain in the a$$ to tune.
Might be some value and 'smoothing' it up but thats all Id do if it was me. Of course Im SD so its not me
GL man.
Old Nov 3, 2009 | 04:25 PM
DopdBrd's Avatar
I too also thought the stock MAF was good for quite a bit of power?
I went speed density, as did two of my other buddies.
Old Nov 3, 2009 | 04:52 PM
Wicked94Z's Avatar
SD is full of win. easy to tune, snappier throttle response imo, and you can run an open tb at the track
Old Nov 3, 2009 | 09:01 PM
jasonisdn's Avatar
agreed.
