Quick question
Old Nov 8, 2009 | 08:03 PM
97REaper's Avatar
Default Quick question
I installed my timing chain and the dots are a little off is this exceptable?? the crank dot didn't show up that good in the picture but you can see it. the crank gear is at 12 o'clock and the cam sprocket is at 6 o'clock the teeth are almost pointed directly at each other.
thanks
Old Nov 8, 2009 | 08:23 PM
SPEED#1's Avatar
Looks good to me and I hope ur on tdc 1?
Old Nov 8, 2009 | 08:37 PM
97REaper's Avatar
ya #1 its at TDC.
Old Nov 8, 2009 | 08:42 PM
97REaper's Avatar
next is to turn the crank till the cam gear and crank gear are at 12 o'clock to install the opti correct?
psiconversion's Avatar
LS1Tech Sponsor
Looks good enough without using a degree wheel.
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
