Running rough
Old Nov 11, 2009 | 11:04 AM
cgEvan's Avatar
Default Running rough
Alright here's what had happened...
Car is running fine, but tune wise it's off due to my MAF.
-Ordered a mail in tune from www.lt1pcmtuning.com
-Datalog is showing the passenger side o2 isn't properly functioning, and the IAT sensor is reading -40* all the time.
-Replace both sensors, car still runs fine.
-Tuner suggests cleaning MAF with cotton swabs and alcohol
-Has trouble cranking, runs a little rich it seems
-Datalog shows drivers side o2 not properly functioning and the knock sensor is pulling timing.
-Car starts cranking fine
-Replace the other o2 sensor and knock sensor
-Car hesitates and runs rough after the first 20-30 seconds of driving. If the SES light comes on, the car runs a LITTLE better. Also clears up at like 4500+ rpm and WOT.
-Try old sensors to rule out a defective sensor, runs the same. Try new MAF to rule out MAF, runs the same. Try reloading the tune, runs the same.
Old Nov 12, 2009 | 07:00 PM
cgEvan's Avatar
Parked it beside an LS1 car with a cocky owner, that I beat at the track a few times, for 2 hours and it runs amazing now.
Ironic. LOL
Old Nov 12, 2009 | 07:04 PM
67goatman455's Avatar
lol, this is all very weird. were all the said sensors replaced with brand new ones?
Old Nov 12, 2009 | 08:04 PM
cgEvan's Avatar
All bought the same day as they were changed. lol
Old Nov 12, 2009 | 08:13 PM
psiconversion's Avatar
LS1Tech Sponsor
Reason idle smoothed out when check engine light came on is because it went back into open loop when it didnt see the O2 working. I had the same problem and it turned out to be a blown headgasket on the side where the O2 was failing. Do a compression check on that bank of cylinders.
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
