carburated motor swap...???
Old Dec 11, 2003 | 02:30 AM
hurtinfeelins's Avatar
Question carburated motor swap...???
i have a 95 v6 camaro and im lookin to put a carburated sbc in it... does anyone know if this is possible or wat i will need to do in order for it to happen...??? maybe even a link to a website will help me out... any help is appreciated!
Thanks in advance...
Old Dec 11, 2003 | 09:11 AM
ChrisB's Avatar
Just get a lt1 k-member - motormounts will bolt up. You will need to cut/modify the cowling a bunch to get a distributor to fit back there, and it's going to be tight. You will also have to deal with getting the gauges working if you rip out the computer control - can be done, or you can just swap to different gauges, just will require time/money/knowledge.
Probably would be easier to just buy a lt1/ls1 vehicle.
Old Dec 11, 2003 | 10:59 AM
yea i was planning on running all new gauges already anyways..... so its gonna take ALOT of mods to the cowl?? will the carb be clear of the cowl??
Thanks for all of your help!
Old Dec 11, 2003 | 12:09 PM
ABrianBaker's Avatar
I did the same thing to my 95 v6.
First and foremost is the motor mount. THE SBC WILL NOT JUST BOLT UP TO AN LT1 CROSS MEMBER!!!!! The mounting location for the bracket is further back. I got custom brackets made for my swap.
Second the cowl. Not that big of a deal however yuo have to remove a lot of material. You have to put the engine in with the distributer on the engine but you have to put the cap on after that. That is a B@#$%.
Obvisouly you will need a new tranny.
then came th cooling issue. The motor liked to overheat. The radiator sits higher that the waterpump. I probably could have fixed this but.....
BUY A LT1 w/ tranny and put it in instead.
See my other thread Computer Problems.
Hope this helped.
Old Dec 11, 2003 | 12:16 PM
Hope this helped.
yea thanks alot that really helped me out i might just go 3rd gen......
Thanks alot though!!
Old Dec 11, 2003 | 01:19 PM
ChrisB's Avatar
What block did you use? I have seen a 400sb bolted up to lt1 motor mounts (the brackets on the k-member)?
Old Dec 11, 2003 | 02:36 PM
im useing a block out of a 93 chevy pickup......
