OEM MAF or aftermarket?
Old Nov 22, 2009 | 08:29 AM
ADM's Avatar
ADM
Question OEM MAF or aftermarket?
Back when I had my opti go out, engine backfired enough times out of the throttle body to ruin the MAF. Kept getting codes for it gone bad with the logs I was making for the tune, so we tuned it out.
Its been tuned out, but would I benefit from using it again?
What am I better off with? OEM or aftermarket?
Was looking at Granatelli MAFs, any experience from you guys?
Old Nov 22, 2009 | 09:46 AM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
Based on everything I've ever read, I would say OEM is a better choice.
Old Nov 22, 2009 | 09:49 AM
Wicked94Z's Avatar
just keep is speed density, its pretty easy to work with IMO
Old Nov 22, 2009 | 09:52 AM
bowtienut's Avatar
OEM....no exceptions!
Old Nov 22, 2009 | 10:38 AM
red-_-z28's Avatar
yep OEM(:
caddy03pimpin's Avatar
Oem ftw
Old Nov 22, 2009 | 10:47 AM
ADM's Avatar
ADM
Any gains in using it again over speed density? As in, will the hp difference be worth the investment?
I know it would probably make the fuel delivery more accurate, but still, what kind of gains am I look at?
Old Nov 22, 2009 | 09:25 PM
MasterTomos's Avatar
for aftermarket? most people lose Hp with an aftermarket MAF...makes the car a bitch to tune plus u cannot really benefit from one unless yur making over 400hp...you'll notice no difference with an aftermarket one and will more than likely lose power.
Old Nov 22, 2009 | 10:13 PM
Elliott's94Z's Avatar
Keep your OEM and stay clear of aftermarket
Old Nov 22, 2009 | 10:37 PM
DroppedM6Z's Avatar
What happen to people going to the 85mm Delphi with the adapter....
Old Nov 22, 2009 | 10:42 PM
ADM's Avatar
ADM
I'm running speed density now. Would I benefit from replacing the MAF with an OEM and reusing it?
Old Nov 22, 2009 | 11:25 PM
Mighty Whitey's Avatar
have know clue what you're setup is, but on my car, bluecat (the tuner) advised that I ditch the O2's and MAF and let him tune it.
I dont 100% remember what his reasoning was for it, but I know the car rides and drives flawlessly, and made 24.5mpg on the highway with 4.10's and a 6spd like that.
leave it speed density, and take the money u would spend on an aftermarket MAF, and put it towards ditching that opti.
Old Nov 22, 2009 | 11:35 PM
ADM's Avatar
ADM
I'm running a CC503 on 1.6 Pro Magnums, Beehives, High-tech pushrods, DIY ported heads with matched intake, blended exhaust ports, Pacesetter long tubes and 3" ORY, 3" piping to the back and Hooker Aerochamber catback, SLP filter, NGK TR55s. Stock stall for now, considering a gear swap soon with the stall.
My O2 sensors are AC Delco replacements. My opti is almost brand new, doesn't have over 1K on it.
Old Nov 23, 2009 | 12:02 AM
JeaneZ28's Avatar
How will you lose HP from a MAF?
Old Nov 23, 2009 | 09:45 AM
same cam, rockers & springs, less head work (port matching) hooker's instead of pacesetters, same cat back, plugs and a K&N CAI with a 6spd and 4.10's here.
bluecat said it wasn't so much about my o2's being bad, as it was any o2 sensor trying to adjust the short-term fuel trim at idle and low-rpm with a semi-agressive cam.
you play russian roullete with your car every time you start it as long as it still has an opti on it.. it could run fine this morning, this afternoon it might **** out.
Old Nov 23, 2009 | 04:33 PM
people switch out the oem ones for granatelli and other aftermarket ones a lot. Over on the formula source forums I saw a guy lose 8hp on a dyno sheet by replacing his oem maf with a granatelli. I might be able to find it if yur interested but i've heard of this more than once, also i've heard they can be a tuning nightmare for some.
Old Nov 23, 2009 | 05:11 PM
AChotrod's Avatar
If you want to get one, just get a stocker and keep the screen in it.
Old Nov 23, 2009 | 09:55 PM
waynehartwig's Avatar
Ok, so if OEM is better than aftermarket, which OEM is the best to have?
Old Nov 24, 2009 | 06:30 AM
hitmanws6's Avatar
any MAF from 93-02 V8 f bodys will work, they are all the same
Old Nov 24, 2009 | 09:39 AM
ADM's Avatar
ADM
An LS1 MAF is also compatible?
