Jumping a ob2 port
Old Nov 25, 2009 | 12:21 PM
96Formula6spd's Avatar
Default Jumping a ob2 port
Hey guys my firebird finally threw a code. So I am trying to find out if there is anyway you can get the pcm to show you code by flashing the check engine light. I know you can do it for ob1 but can you do it for ob2. Or am I going to be buying a reader?
Old Nov 25, 2009 | 01:47 PM
quicksilver383's Avatar
As far as I know the jumper method to retrieve codes went away with OBD1 so now you have to buy a reader.
Old Nov 25, 2009 | 01:56 PM
shbox's Avatar
Can't be done by anything other than a reader, scanner or logging software.
Old Nov 25, 2009 | 03:37 PM
koolaid_kid's Avatar
Many auto parts stores will read your code for you. It is up to you, however, to figure out what it really means.
Old Nov 25, 2009 | 04:43 PM
96capricemgr's Avatar
Just for clarity the jumper trick will NOT work on all OBD1, it does NOT work on 94-5 LT1 cars but they are still OBD1.
Old Nov 25, 2009 | 07:52 PM
Yeah was just making sure before I forked out the money for one. Car is not going anywhere since the icm is bad.
