Header Horror Stories
Old Nov 27, 2009 | 11:13 AM
mbowtie71's Avatar
Default Header Horror Stories
Tell me about how your long tubes fit. Its time for an upgrade on my 97 Camaro. I really want Kooks, but holy expensive!!! I am thinking about Pacesetter black painted and then sending them to Jet Hot for a coating. I also need catalytic converters here in Georgia to stay emissions legal.
Old Nov 27, 2009 | 11:29 AM
Z28_LT1's Avatar
i had coated pacesetters LTs and they fit good. I got both of them up through the bottom of the car. If wasn't as tough as I thought, but I would say the hardest part is lining up the header with the gasket with the head. hardly any room but we got it done.
Old Nov 27, 2009 | 12:10 PM
TheDon619's Avatar
you need to stay emission legal in ga? when i went to college there i had my 95 formula with no cats, headers and a bullet muffler, never got stoped.
1993 z28 f1's Avatar
Hey:
Nothing beats stainless headers, except Inconnell, and that is real pricey.
321 stainless is real good thats why LPPs were so popular even if a few folks had fitment issues which were mostly due to worn motor mounts. Coated headers will burn off and rust. Go with ebay stainless pacesetters clones, before you buy a coated header. I have not read one intelligent post dissing them and the price is great. Just make sure they look just like the pacesetters and are 304 stainless. Do a search and you can find the exact ebay seller everyone has had good luck with. I think its eworld sales. Don't forget to do poly motor and tranny mounts while your in there. The stainless clones don't have very many problems except a few burnt plug wires(reroute and Protect) and the occasional steering rack interference. (Just slot and move) Also you may have to get a smaller oil filter and remove the oil cooler if you have not done so already.
Good Luck
Dub
When In Doubt Do Without
Old Nov 27, 2009 | 12:17 PM
integraxtc's Avatar
Same here. Same headers.
It was a bitch getting all three to line up. I felt like getting studs instead but at the same time that reduces the space even more to maneuver.
Old Nov 27, 2009 | 12:34 PM
Badazz 97 TA's Avatar
why not just save the hassle and time and buy coated then? Its a bitch but they fit fine once in place. there a billion threads on this so just search
Old Nov 27, 2009 | 12:45 PM
Hey:
Don't forget to shield/wrap your plastic fuel lines anyplace they come near the exhaust with some form of alloy or foam heat shield to protect them or we will be reading about a new header horror story.
Dub
Old Nov 27, 2009 | 01:09 PM
marc97taws6's Avatar
Originally Posted by 1993 z28 f1
Hey:
Dub
Where would you recommend buying these parts?
Curious as I am doing a coated Jethot LT header system come spring
Old Nov 27, 2009 | 01:30 PM
SlowestTransAm's Avatar
I had a lot of trouble with my first install.
One of the shittest parts was when I lifted the engine, got everything on, put everything back and was about to start her up when I realized I never put the gaskets on.
Old Nov 27, 2009 | 02:00 PM
Hey:
marc97taws6:Where would you recommend buying these parts?
eworlds sales on Ebay or Summit. I used custom made alloy plate covers with the foam and fiber heat wraps where they fit best.
Dub
Old Nov 27, 2009 | 02:10 PM
Huff035's Avatar
Ouch..
Gaskets are the biggest PITA then the occasionally header bolt coming loose and blowing a gasket. Um...spark plug wires also a PITA. don't go buy MSD's and then let them get burnt...
Old Nov 27, 2009 | 08:57 PM
technicality's Avatar
i got jet hot coated pacesetters. they fit perfect and still look like new even after two years . and its a daily driver. actually installed mine from the top, couldnt get them to fit from the bottom.
