Weird Brake Issue
Old Nov 27, 2009 | 01:51 PM
transamws6_97's Avatar
Default Weird Brake Issue
I'm having a issue with my ebrake. I pull the handle up until it's tight and the passenger side rear wheel holds good but my drivers side wheel isn't holding. I was checking it out while I had someone pulling on the handle and on the driver side the cable will pull the lever when the handle is raised but when you release the tension the lever on the brake doesnt return to the previous position before it was pulled on. Not sure if the spring is not pulling it back or maybe from this issue my brake pad has been worn down? But it's acting normal on the passenger side.
