Flexplate???
Old Nov 29, 2009 | 10:46 PM
1C3 MAN's Avatar
Default Flexplate???
okay i have broken 3 flexplates so its time to upgrade.
So what are some good brands that wont crack after 6 months?
I have looked around and found a company called TCI that makes heavy duty ones. any of you use them if so how are they? Also found one from B&M.
Old Nov 29, 2009 | 11:14 PM
SPEED#1's Avatar
Tci will be fine and they are sfi approved, but WHY are you breaking so many flexplates???
Old Nov 29, 2009 | 11:34 PM
1C3 MAN's Avatar
Thats what id like to know. they keep cracking around the bolt holes. any ideas would be appreciated.
Old Nov 30, 2009 | 08:56 AM
Pocket's Avatar
Cracking at the crank bolts means you are running too much power for a cheap flexplate and need to upgrade
Cracking at the converter bolts means its out of alignment somehow. Check that the snout has a seat
Old Nov 30, 2009 | 09:24 AM
LS1 SPEED's Avatar
TCI here and recommended on any car with H/C or spray along with an upgraded stall
I would also check the converter for proper alignment and the snout is seated as noted by Pocket.
