Problem with EGR......
Old Dec 3, 2009 | 07:57 PM
1 Craz28's Avatar
Default Problem with EGR......
When I took my car out for a drive today, after a few miles, it melted the drivers side EGR tube where it hooks up to the header flange. Then it would almost stall out. Anyone ever had this problem before?
Old Dec 3, 2009 | 08:23 PM
1 Craz28's Avatar
I'm thinking it may be a bad O2? Or maybe I should extend the metal tubing from the header flange on the drivers side EGR hook-up? Any thoughts?
Old Dec 3, 2009 | 08:38 PM
red-_-z28's Avatar
delete the EGR, it will cause no harm
Old Dec 3, 2009 | 09:06 PM
shbox's Avatar
If you are melting the rubber hose, the check valve is probably bad and letting the hot exhaust through.
93s are a whole different animal with regard the the combined AIR and EGR piping.
http://shbox.com/1/1993_air_egr.jpg
Old Dec 3, 2009 | 10:10 PM
1 Craz28's Avatar
YES, that was exactly what I was just thinking! Seems the check valve, drivers side, should only let the smog pump air INTO it and not let exhaust out. Correct? It's a one-way valve right?
Old Dec 4, 2009 | 06:51 AM
shbox's Avatar
Yes, the check valve is mean to let air from the pump in and no exhaust out.
