LT-1 Head porting. Help Please.
Just blend the edges of the outlets, if you feel them, they seem to be cast inwards, like a slight necking. Nothing but shaving a tiny bit. Mirror polish the port if you can, smoother the better.
What bout Gettin them shaved though? I was thinkin about that The Other Day. Get them cut to boost the Compression, but i didnt know if i would need to cut the intake too?? any advice on that??
I attended the School of Automotive Machinists and took both, the block and head courses and the bowl is the most important part of the whole port, other than the valve job...its very hard for the beginner to actually do more good than bad without a flowbench...a dremel i guess could get you by since you do not own an air compressor and the trimmings...but the school issued us huge milwalkee electric grinders that have a 1/4in. collet and they use 1/4in. shank carbide burrs with various tip shapes and sizes...i would say send the heads to a shop...
This has been my experience also. My machine shop told me the LT1 exhaust is where most of the gains are, so I went pretty far above the short side radius and did some nice smooth bowl work. I used telescopic gauges to measure. Overdoing the intake areas can get you into trouble though, so just smoothing the intakes and doing a bit of bowl work is all you need since only a limited amount of the gains are there. I only use a Dremel on the combustion chambers to remove the roughness and do some polishing. The rest I do with carbide burs, sandpaper rolls and pneumatic die grinders. BTW, it's pretty hard to make them worse than stock unless you really get stupid. GM castings are really damn rough. Just smooth things off, remove the casting crap and round off the bowls.
