Power Locks
Old Dec 4, 2009 | 07:42 PM
Z28reggie's Avatar
Default Power Locks
Trying to fix my power locks any advice on wher to start i can hear them some times trying to lock and unlock when i push the switch but they seems like they dont have enough power to do it
Old Dec 4, 2009 | 07:59 PM
1995blacktattop's Avatar
bad switch maybe? could be that the contacts are worn
Old Dec 4, 2009 | 08:14 PM
Z28reggie's Avatar
i have new switch had to buy that to find out the things didnt work lol guy aid switch was broken like gone out of the door so i found one in a part car that works but now they just arent working lie they should i been to alldata and have my wiring diagram so i will check all that tomorrow just wondering if anyone else ran into this problem
Old Dec 7, 2009 | 11:20 AM
slow96z's Avatar
I had the same issue, locks wouldn't work with the switches, but I knew they worked because they locked and unlocked when I put the car in keyless programming mode. When we did the alarm I just ran new wires to the actuators in the doors and hooked them to some relays, then had the switches just throw grounds to the relays like the lock and unlock outputs on the alarm do. Works great, but if you have factory keyless it will no longer function.
