Trying to Identify a wiring plug under steering column
Old Dec 5, 2009 | 12:20 PM
355z28's Avatar
Default Trying to Identify a wiring plug under steering column
Im almost finished with my lt1 swap in my 93. There is a pretty small plug under the dash around the steering column that is 2 pins with a black and white wire. Any one know where it goes?
Im trying to find loose ends here, I transfered complete dash harness, engine bay harness, and engine harness out of a 95 T/A into this thing and I cant get it to turnover. All the accessories work, lights, fuel pump but the starter wont enguage, I've checked to make sure everything was connected.
Old Dec 5, 2009 | 01:45 PM
camaronutt's Avatar
maybe it has something to do with the vehicle anti theft system. The plug for that has 2 wires. The key pellet has to match the VATS module or it won't start. I would think it would crank though. Just a guess. Good luck.
Old Dec 5, 2009 | 01:59 PM
355z28's Avatar
The vats module, and column both came out of the donar car. So the key is the same. This plug has a white clip, with a black and gray wire, and two very small pins, its located 3 inches or so left of the column. I try to get a picture.
Old Dec 6, 2009 | 11:47 AM
robsquikz28's Avatar
pic would be awesome
Old Dec 6, 2009 | 09:53 PM
355z28's Avatar
rob check a few threads down, mattcossel29 posted it for me. Thats man
Old Dec 7, 2009 | 10:47 AM
sweetbmxrider's Avatar
my buddy had a 97 trans am and couldn't figure out where it went either, he didn't do a swap though and his runs. let me know if you find out.
Old Dec 7, 2009 | 10:52 AM
wrd1972's Avatar
Same here. Was never used from the factory on my car.
