Heater hose questions,...
Old Dec 5, 2009 | 01:03 PM
WHITEBOY_ZACH's Avatar
Default Heater hose questions,...
I just picked back up on my LT1 swap and I have a few questions.
I only got two pieces of hose with the motor,... one with the check valve, and one with the bleeder screw.
I am also using a v6 radiator so it doesnt have the small hose on the drivers side.
Can I just put a cap on one of my water-pump tubes? If so,wich one??
Then,..wich two tubes do I use for the heater hoses.
I did a SEARCH, but only came up with people removing the hoses. I also lookes at shoebox but I still cant figure it out.
Im still pretty new with these cars.
Thanks in advance for any help,
ZACH
Old Dec 5, 2009 | 04:30 PM
robsquikz28's Avatar
You need a v8 radiator big time. As for the hose they both go to the water pump. The check valve goes on the bottom of the pump, the bleeder is on the top of the pump.
Old Dec 5, 2009 | 04:39 PM
fleetmgr's Avatar
If you use a v-6 radiator, plan on doing headgaskets pretty often. It doesn't have enough cooling capacity to keep your engine cool.
