What plug wires with LTCC kit?
Would these work? I can't figure out what length they are:
http://www.summitracing.com/parts/TA...n/?prefilter=1
Or do I have to buy LS1 wires?
You'll need a set with LS type sockets on one end and 90 degree plug boots on the other. I suggest high temp sleeves at the plug ends. I also suggest you stay away from Taylors.
The LTCC guide says you can't use low resistance plug wires. MSD wire should work well for you.
I have these in the box waiting to cut them to fit.
I know of another guy running them with no problems.
There was a report here on LS1tech that the Taylor wires burned through quickly and also arced. I popped my hood in the dark with the engine running and did find some arcing. After pulling them, two had arced through the insulation. Several other people reported the same issues.
I swapped to the MSD's and the problems went away.
Here's what to do guys: When you go to the race track and look at the professional cars that win a lot, look what they're running. MSD is what the big boys run.
Honestly, I'd like to give the Granatelli 0 Ohm wires a try but at $150.00, they'll have to wait.
Direct from Turbo Bob's website the maker of the LTCC:
8-#12558948 coil
Taylor Spiro-pro cut to fit wires or equivalent (NOT ultra-low resistance type).
1-LTCC Module/Harness
Coil mounting provisions
http://www.bailey-eng.com
Either LS1 or LT1 wire kits work and have to be cut to fit from wherever you mount your coils, I use straight wire ends at both ends.
Dub
When In Doubt Do Without
