is there any difference
Old Dec 15, 2009 | 09:52 PM
speedracer2536's Avatar
Default is there any difference
in running the iron heads versus the alum. ones in an lt1? has anyone done it? should i steer away from this
Old Dec 15, 2009 | 10:11 PM
robsquikz28's Avatar
If thats all you have then use them otherwise the iron does weigh more and you will have to use the .026" head gaskets with them. If its stock it will be just fine but I would recommend going with aluminum.
Old Dec 16, 2009 | 06:53 AM
DAVE00's Avatar
The only difference as stated really is the weight and the fact that Alumin heads dissapate heat better/faster and that is why the Fbody's run a higher compression then the bbody (where the iron heads are found). If you are going to do some work to them alot of guys will say the iron heads flow better and will open up more, but I'd still stick with the aluminum heads even if you decide to have em' ported.
