I'v got an issue
Old Dec 19, 2009 | 04:46 PM
93TAJ.C.'s Avatar
Default I'v got an issue
My clutch disc split about 2k ago, so i just got a new valeo replacement clutch disc and gave the pressure plate and flywheel a good cross hatch surface. Well now thats it all together and running, it has very very good bite, and minimal hop, but has a high speed vibration at about 2000rpm, or when you get over about 95 it gets pretty bad. I dont know what it couold be to cause a vibration at a certain rpm and high speed. U joints are good, there was not a single vibration before the clutch went. When the clutch split, it did take a tiny chunk of the pressure plate with it, but i wouldent imagine it could be that.
Old Dec 21, 2009 | 11:41 AM
pyro719's Avatar
Does it do it in nuetral? Or is it just while driving?
Old Dec 21, 2009 | 12:18 PM
2fast4u88's Avatar
Try flipping the driveshaft if it does it while driving in the upper mph range.
Old Dec 22, 2009 | 02:37 AM
93TAJ.C.'s Avatar
Seeems to only do it while driving. I'm almost certain its driveline and not engine. It started when i got the car back together after fixing the clutch. I'll flip the ds and see what happens.
Old Dec 22, 2009 | 08:55 AM
pyro719's Avatar
Like stated above, flip the drive shaft 180 degrees I have this problem too @ about 85mph
Old Dec 22, 2009 | 09:20 AM
93TAJ.C.'s Avatar
Yeah i"ll give it a shot. Thats the only thing that would make sence at this point because it had no vibrations at all before my clutch went.
