power stumble
Old Dec 19, 2009 | 04:47 PM
redhot lt-1's Avatar
Default power stumble
i recently replaced my water pump when i was pulling it i found an oil leak from the front timing cover seal (crank shaft seal). well pulled it had to remove the opti. i have the dynatech opti no a stock style unit. so i checked it and it was in good order. it take about 3 weeks for me to get this done (other things got in the way weather and the like. now at some high rpm i have a slight stumble its not bad but there it doesn`t hit in the same spot evertime. the only thing i can think is some trash in the system but not sure. anybody got any ideas let me know.
thanks
Old Dec 26, 2009 | 11:22 AM
maddog05's Avatar
Default It could be many things ~see below
Check: coil wire
plug wires
loose ignition connection
moisture in opti
vacuum leak in elbow
02 sensor
engine temp sensor
injectors
l
Old Dec 26, 2009 | 04:56 PM
Originally Posted by maddog05
Check: coil wire
plug wires
moisture in opti
02 sensor
engine temp sensor
injectors
l
plug wires are new, checked all ignition connection there good, opti has some oil on it but it`s vac lines are routed to he top of the engine there are no o2 sensors temp sensor is new and the injectors ? not sure.
Old Dec 26, 2009 | 06:29 PM
pillarpod's Avatar
my stumbled in the upper rpms due to a burnt plug
