OBD1 data logger
Old Dec 23, 2009 | 10:06 AM
94T/A5.7LT1's Avatar
Default OBD1 data logger
What's a good one to use?
Old Dec 23, 2009 | 12:15 PM
aboatguy's Avatar
I use Datamaster and an AKM cable. I started with his rs232 connector cable and a couple years later I sent it back to be upgraded to a usb cable.
http://www.akmcables.com/
Mike
Old Dec 23, 2009 | 12:34 PM
Colin91Z's Avatar
I also use TTS Datamaster.
Old Dec 23, 2009 | 12:57 PM
ADM's Avatar
ADM
TTS Datamaster has been useful with me
Old Dec 23, 2009 | 01:57 PM
Formula350's Avatar
I'm sure you know as well, there is going to be a difference in software/cable between the 93 and 94 models. 93 uses the older ECM and when they switched to PCM in 94, things changed quite a bit. Pretty much like PC and Mac The cable is a bit more hit and miss though. I've came across a few people on the forums with a 94 that has the OBDII style connector, even if most will be OBD1. Corvettes (which by your name, I'm assuming you don't have heh) in 94 had the OBDII style I think throughout the whole year. This is what he says: "The year breakpoints for OBDII style connectors go: 1994+ Corvettes, 1995+ F-bodies, and 1996+ B-bodies. ", but again I've came across a few folks here with OBDII style in their 94 F-Body. Probably those that were at the end of the model year is why, which I think is like July (07/94) being last build month for that model year (but not sure).
I wish AKM's weren't $90 though :\ I wish the scanner I have with detachable cables wasn't a special connector, but something like a computer's network cable (RJ-45) style, then I could at least ask him for just the portion he uses for the USB part and make my own conversion
Old Dec 23, 2009 | 02:11 PM
djjab57's Avatar
Data master here as well, I have an early 94 and its OBD1. When i bought my AKM cable i just got the one with both connectors on it
Old Dec 23, 2009 | 02:25 PM
shbox's Avatar
That's a new one. Never heard of such a thing, myself.
Agree with Datamaster for the OP.
Old Dec 23, 2009 | 02:31 PM
FASTFATBOY's Avatar
Freescan is another option
Old Dec 23, 2009 | 02:45 PM
Formula350's Avatar
Unless it was OBDI style 1995s, but I doubt that lol
Eitherway, who cares heh
Old Dec 23, 2009 | 02:52 PM
djjab57's Avatar
yes some 95 are OBD1
Old Dec 23, 2009 | 04:14 PM
shbox's Avatar
All 95 LT1 f-body cars are OBD-I (the DLC is OBD-II shaped).
Old Dec 23, 2009 | 04:23 PM
wrd1972's Avatar
I might be wrong. But Freescan is only a monitor and NOT a data logger. TTS datamaster works great.
Old Dec 23, 2009 | 04:34 PM
djjab57's Avatar
I knew it was something like that, You are all knowing shbox. I dont ever dout you
Old Dec 23, 2009 | 04:37 PM
cgEvan's Avatar
I'll sell the ALDL cable I used with my '95 like 10 times
