help me for convert LT1 to carb
Old Dec 26, 2009 | 04:04 AM
EmPeRor's Avatar
Originally Posted by 2manytoyz
gas tank for carb,maybe a older 3rd gen tank
I do not understand you
Thank you
Old Dec 26, 2009 | 05:29 AM
ADM's Avatar
ADM
Emperor, I did mean gearbox. If its off road only install either a TH400 or TH350 to run with the carb engine. A good torque converter will serve you well.
You guys have no idea how big the engine bay is on a Nissan Patrol, he will have all the space in the world for an air filter.
Old Dec 26, 2009 | 09:06 AM
GIZMO's Avatar
12367600 - LT1/LT4 Front Cover Plug (Does away with the Opti-Spark)
24502592 - LT1 Intake Manifold (Carb)
12524653 - Gasket Kit, LT1 Four-Barrel Conversion
You will also need an electric (low pressure) fuel pump, because there are no provisions for a mechanical fuel pump on an LT1.
I would suggest using a HEI distributor, because it is simple to hook-up and doesn't require much maintenance.
If you are leaving the stock cam in, I would suggest running a carb no larger than 650 CFM.
Depending on which fuel pump you choose you may need a regulator.
You will need a new fuel filter.
Old Dec 26, 2009 | 11:25 AM
ADM's Avatar
ADM
I'm really itching to convert to carb on my 94, cheaper than doing the 24x Connections LS1 pcm conversion.
Old Dec 26, 2009 | 02:09 PM
EmPeRor's Avatar
thank you
the space is very big
If i want Big Block no problem
See the picture
Gearbox will not be Auto
Gearbox the car i not Change[/COLOR]
Old Dec 26, 2009 | 02:12 PM
EmPeRor's Avatar
Thank you
Words correctly
Everything is almost ready
Repeat my thanks to you
Old Dec 26, 2009 | 02:13 PM
ADM's Avatar
ADM
Bro, I'm from Bahrain, I know what the car was going to end up looking like you want to surf the sand dunes!
Yella, get yourself a T56 transmission and get it running.
Old Dec 26, 2009 | 02:21 PM
EmPeRor's Avatar
Why does not speak Arabic Mai previously ?
but
Recommend
Carpritr Holly size of 750
or not
thes car not go to sand dunes Every day
More use in Street racing
Old Dec 26, 2009 | 02:37 PM
ADM's Avatar
ADM
but
Recommend
or not
Don't have Arabic keyboard on my laptop, never use it
The guys mentioned earlier that if on stock cam, get 650CFM. Make sure you get a fully manual carburetor.
Old Dec 26, 2009 | 02:49 PM
GIZMO's Avatar
One thing that you might want to look at if this thing is going to spend a lot of time off-road is an aftermarket oil pan. The extra capacity and oil control will help the motor last.
Old Dec 26, 2009 | 02:50 PM
EmPeRor's Avatar
I am in Riyadh
it is stock cam but i Possessed Now holly 750
Old Dec 26, 2009 | 02:54 PM
  #32
EmPeRor's Avatar
Evaluated per liter of gasoline it 0.1$
By Brett Foote | 2026-06-04 05:00:17
