EFI connection and FAST
Old Dec 26, 2009 | 02:03 PM
355TurboLT1's Avatar
Default EFI connection and FAST
Seriously considering the new EFI connection 24x conversion for my 355 build. Does anyone know if this system will jive with a FAST or accel standalone? Really dont think an LS-1 ECM is capable of the hp i am looking for here. Thanks
Old Dec 26, 2009 | 03:27 PM
Puck's Avatar
If it is outputting the proper cam and crank signals to drive an LSX computer, then it shouldn't be a problem to run a FAST off of it.
Just make sure you wire the harness carefully and have the proper bank assignments.
SRZ's Avatar
SRZ
I asked this very question and was told it can be done but w/ some trickery involved. To me I think that's damn near the ultimate setup.
Old Dec 26, 2009 | 05:24 PM
LS1 SPEED's Avatar
how much power are you looking to make? We have been over 1000HP with a stock LS1 ECU / 3 bar setup with 0 issues.
97Z28SS's Avatar
Maybe Wildside S10 from EFI Connections will chime in and answer your question.
Old Dec 26, 2009 | 08:47 PM
Looking to make around 1000rwhp with a PT-88 and my built 355. This Ls-1 ecu thing is news to me. Im very interested in a EFI connection system. IF this is more than doable what program do you recommend for tuning. I live in phoenix and it seems people only deal with FAST and Accel. I have both systems but hate the fact I have to have a expensive custom harness built to retain my gauges and A/C. Any insight on this would be greatly appreciated. Thanks!
Old Dec 26, 2009 | 09:00 PM
97Z28SS's Avatar
Well I just brought the complete EFI Connection 24x kit with all the bells and whistles, the custom engine harness, 01 LSx pcm, billet timing cover and modded cam sensor housing and the 24x reluctor for the dr timing set I'm running on my 383 LT1. I'm waiting for all of it to arrive, they recommend EFI Live for tuning software and I sent my PCM to (doc@efialchemy.com) for a base tune customized to my setup.
Old Dec 26, 2009 | 09:06 PM
LS1 SPEED's Avatar
We us HP Tuners and could help you with a base file to get you rolling with the setup. We will be doing a 2 NA 24X setups and 1 D1SC setup in a couple months and we have done many high HP Lsx FI setups.
The only issue might be injectors, but they are constantly working on large hi impedance injectors.
keep us in mind when you are ready
Old Dec 26, 2009 | 09:14 PM
96lt1m6's Avatar
check the FORCED INDUCTION section you will be suprised with the Ls1 PCM
Old Dec 26, 2009 | 09:34 PM
Sounds good. Yeah I would assume I will be running about 72lb injectors on this setup. Really would like to be able to not have to run a versafueler. Ever time I turn around its something else. Thanks for your help. Orering the EFI connection system sometime next week.
Old Dec 26, 2009 | 11:43 PM
LS1 SPEED's Avatar
We usually run 80's and depending on how efficient the combo is will determine how far the injector will go.
Old Dec 27, 2009 | 05:58 AM
Ponch95's Avatar
Errrr Larry don't you mean 3 my car's coming in April.
Jim
Old Dec 27, 2009 | 10:46 AM
LS1 SPEED's Avatar
opps...yes you are correct.
Q is do I put you down for NA or FI
Old Dec 27, 2009 | 11:53 AM
Larry I will be calling you here pretty soon. Thanks for your help!
Old Dec 27, 2009 | 12:58 PM
LS1 SPEED's Avatar
glad to help and never hesitate to contact me for anything
larry@speedinc.com
Old Dec 27, 2009 | 06:07 PM
S10Wildside's Avatar
When the LT1 is equipped with the 24x components (24x crank sensor/reluctor and 1x cam sensor/reluctor), electronically you can consider the engine an LS1. And if the FAST ECU can control an LS1 engine (and it can), then it can control a 24x equipped LT1 engine. And this is a bolt-on crank/cam signal solution. No messing around with signal adjustments. Bolt it on and you're ready for the harness and ECU.
I hope this helps.
If you require higher resolution, you could run with 58x equipment. Personally, I don't think I would...but it's now an option. Bigger (58x) is not always better (than 24x). The Gen IV GM ECMs can be more challenging than the Gen III GM PCMs.
So in this case, if the FAST ECU can operate a Gen IV LS engine (LS3/LS7), then you can run the same FAST ECU on a 58x LT1.
Old Dec 28, 2009 | 11:28 AM
I hope this helps.
Thanks alot! I will be in contact with you shortly.
