xfi 292 cam
# XFI" 292 Hydraulic Roller CamshaftGM LT1 & LT4 350ci 1993-96
Lift: .584"/.579" w/1.6 Rockers
Duration: 292°/300°
RPM Range: 2200-6200
With a stock shortblock a good general rule is to stay below 230degrees on the intake.
)We talking stock heads, like with stock springs? Coil bind and snap, crackle with those lift numbers on stock springs...
Even with stock 1.5 SA, the lift numbers are still .548 I/.543 E on the 292.
Anybody know the stock springs coil bind point (looking for it now)?
Ai 230 / 238 - .575/.575 - 110 LSA Primary Operating Range: 2300-6400rpm
This is our largest stock long-block cam for M6 cars. Excellent for rebuilds with 11:1 compression. Lopey idle, good drivability with gears & tuning, and excellent mid-range with peak power at approximately 6300rpm. Properly tuned w/ supporting modifications, M6's typically produce 350-365rwhp SAE corrected.
OP, I'm not trying to hijack here as you did mention heads down the road.
