Oil weight and brand?
I am merely looking to see what you guys use. I am not looking for a recommendation but understand I may have not been clear with my intentions. Some of the obove info may or may not be review. But I can say without a doubt that running a 40wt in your LT-1 or any motor for the most part will not lead to scoring of the bearings and increased wear in a short amount of time. I actually ran Redline 10w-40 in my LT-1 (stock short block) for near 30k with a blower and it looked great upon tear down, as it should. I am not the end all know all of lubrication.I just want to set the record straight.
Except for the coolant path they are very similar engines. an LT-1 would generally have a flat tappet and that would like ZDDP but other than that they are VERY much the same.
Oil pressure does not matter, oil FLOW does, just easier to measure pressure and all we need to watch for is a sudden change in pressure indicating a change in flow.
ZDDP is NOT critical for bearings, bearings the pressure fed bearings are kept apart from the part they support by what amounts to hydroplaning.
ZDDP was important to parts that did not get pressurized oil like flat tappets. How many of you are running flat tappets???
The M1 5w-30 everyone mistakes for wonderful is nothing more than decent in an LT1 or LS1.
The belief that 10w-30 is thicker at operating temp than 5w-30 is proof of no real understanding on the subject.
At one point I saw data on oil recommendations for export LT1s and they got 15w-40, the b-body was very popular in the middleast, before you dismiss that as a hot weather thing, it get plenty cold in the desert at night.
North American oil recommendations are CAFE driven, HonDa and Furd did not go 5w-20 for more protection, they did it because it provided adequate protection and gained them a fraction of a MPG.
If you READ the owner's manual that came with your car you will see 10w-30 approved down to 0F.
The LT1 has some differences when compared to an LT-1 as noted. The guy was just curious and asking a question.
EDIT
Meant to say comments were NOT aimed at you. Sorry I think faster than I type.
Had I gone back and read my own post a lot of confusion would have been avoided.
Again I said my comments were NOT aimed at you. Stop looking for something to get bent out of shape about and you will feel better.
Look at Al 96 Ram Air T/A's post and you will see my comments are directed more at him.
He is advocating switching weights seasonally in a location that is 10w-30 compatible year round. I lived there 17years so I know the weather.
That is besides the fact that I know at one point M1 5w-30 was THICKER at operating temps than their 10w-30.
He is also the one that said 40wt would "score the bearings". The overwhelming majority of us know better.
