lt4 has no spark....
Old Jan 7, 2010 | 04:34 PM
monchis's Avatar
Unhappy lt4 has no spark....
i have replaced everything! except my coil blaster.....i replaced mi distributor and cap and rotor and even my ignition module but didnt replace my msd blaster due to the fact that it's not that old....but what else could be the problem should i just replace the blaster as well????help please......
Old Jan 7, 2010 | 04:40 PM
djjab57's Avatar
Replace the coil, also i have bought a bad ICM before, make sure it is good
Old Jan 7, 2010 | 05:10 PM
monchis's Avatar
what coil would be the best brand for durability??
Old Jan 7, 2010 | 05:14 PM
djjab57's Avatar
ive used the MSD blaster, hypertech and accell but the stock replacement is what i always come back to myself
Old Jan 7, 2010 | 05:16 PM
djjab57's Avatar
and when i had stock wires the blaster was causing it to spark outside the boot, causing more problems
Old Jan 7, 2010 | 07:05 PM
monchis's Avatar
Well i have the accel 8.8 racewire so maybe the same one would be best i think.......wich is a msd but how can i be sure it's that cause i already spend way too much money and still no spark........
Old Jan 8, 2010 | 03:11 PM
blackz93's Avatar
The last one that went out on me was an MSD.
Old Jan 8, 2010 | 04:20 PM
WARDOG's Avatar
Default Codes
Hey is it throwing any codes? How old is your crank sensor??
Old Jan 8, 2010 | 04:56 PM
djjab57's Avatar
My MSD didnt go out but the clip that holds the plug in broke off
Old Jan 8, 2010 | 09:14 PM
transam5.7lt1's Avatar
ICM can be tested at your closest Advance Auto, just remove it and take to the store.
Old Jan 11, 2010 | 02:11 AM
polywod's Avatar
need more info. why did it stop working
Old Jan 11, 2010 | 02:13 AM
SS#502's Avatar
Make sure you have a really good ground to the ICM. I ended up using some battery cable for mine for extra insurance and haven't had a problem since.
Old Jan 11, 2010 | 03:40 AM
monchis's Avatar
at first my cap n rotor went bad so i replaced iit along w/ the distributor.....car ran for a day or two then stopped starting in result to no spark....checked the icm and was bad so i replaced it as well and still no spark at all!!!im runnin out of ideas......
monchis's Avatar
any help will be appreciated......thanks
Old Jan 11, 2010 | 03:57 AM
LT1's Avatar
LT1
I never recommend replacing cap and rotor on LT1's, always replace the whole unit. On the opti spark there's more than just cap and rotor that wares out.
Have you test your plug wires to make sure they are good?
You can actually test ICM, coil, plug wires, opti harness while its off the car. Make sure your ground connection is ok too.
Old Jan 11, 2010 | 04:15 AM
blkcamaro_z28's Avatar
I dunno if it would run for a day or two and then quit but maybe you didn't get the pin slot from the distributor lined up with the cam correct. I'm not for sure about any of that but hey its worth a shot if your running out of ideas.
Old Jan 11, 2010 | 04:49 AM
06 SS's Avatar
I have personally seen MSD's go bad after a few days, as well as right out of the box. Go get a stock coil and I would bet you are fine.
Old Jan 11, 2010 | 01:53 PM
SS#502's Avatar
I've gone through two MSD 6AL's. Try disconnecting it and run just the stock set-up and see what it does. When my second box went bad it also burnt the plug that connects to the top of the coil. That cost me another $45. Double check that ground wire for the ICM, my stock one was corroded on the inside and gave a lot of resistance. I changed 3 ICM's before I even considered the groundwire.....
Old Jan 11, 2010 | 08:36 PM
black_byrdWS6's Avatar
Why dont u convert the car to to coil pack system?
Old Jan 12, 2010 | 08:41 PM
monchis's Avatar
how would i convert it to coil pack system......im gonna go ahead and get a new stock coil to see what happens then....
