good grounds?
Old Jan 9, 2010 | 02:13 PM
tnnt's Avatar
Default good grounds?
I have recently relocated my battery to trunk but have not reconnected the battery yet.
i have used 0guage wire from my battery to the front of the car.
My question is for grounds: I have used the frame rail in the back as a ground for the battery, I used a special ground block that is held in place with two screws bolted to frame rail, Is that a good ground?
2nd, I used the same grounding block in the rear and removed paint just behind the headlight for the grounding location is my second position ok as well?
i have done alot of searches for good ground positions but Im just not 100% sure with mine
Old Jan 9, 2010 | 02:32 PM
tnnt's Avatar
lil help please
Old Jan 10, 2010 | 01:39 AM
the_merv's Avatar
Veteran: Air Force
I would put some 4ga or 6ga from the Engine Block to the Frame Rail up front for a little added help..grounds are your friends with this.
