Stealthram or Carb Single Plane Intake
I was real sweet on the Holley Stealthram and I have the room for it under the hood. But I learned that it has the same poor air distribution issues as the stock LT1/LT4 intake has. In that especially at part throttle the rear (4) cylinders get straved for air than the front cylinders that are closer to the throttle body.
Than I got on the Carb Style Single Plane EFI intake bandwagon with a progressive 4 barrel throttle body. Here most guys say don't bother with this setup inless you intend to build a max effort motor in a car that is trailered to the track not in daily driver which my car is.
Please tell in your opinion what do you think is the best for my application???
No need to 'overbuild', IMO, for "only" 400whp.
im going with a single plane EFI manifold but my car is getting a little bigger cam and i wanted even nitrous distribution. also it will allow me to go to some bigger heads when i switch to a FAST system and want to spin it higher
