Coil Wire Arching!!!!!!!!
Old Jan 11, 2010 | 05:31 PM
1 Craz28's Avatar
Default Coil Wire Arching!!!!!!!!
Tonight I found out the importance of checking spark-plug wires in the dark! Thinking I would never have a problem using 10.4mm Taylor wires. After poping the hood I found my coil wire arching on the TB's coolent line and saw an arch on the valve cover from a wire! WTF! Luckily, my AC Delco coil wire was in the mailbox! After installing and starting, after a minute the car idled and revved smoother. I also noticed that the GM coil wires are year specific? I think mine is for 93-95 and they changed it later, probably a different length? Is anybody using extra shielding on there wires?
Old Jan 11, 2010 | 06:05 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Yep, Taylor wires have recently been found to be prone to arcing although some people won't believe it. MSD’s work well.
I used fire shielding at the plugs when I had the '94.
Old Jan 11, 2010 | 11:22 PM
projekt70chevelle's Avatar
I have gone through 5, maybe 6 coil wires over the past 2 years. Used taylor, stock ac delco replacement, autozone wires (even using insulator socks to prevent rubbing) and I still have had problems with the coil wire arcing on the coil itself. Don't know why I keep having this problem but it's damn annoying. I figured maybe there was resistance in the rest of the ignition system, but it's all been replaced for the most part.
Fire shielding???
Old Jan 12, 2010 | 06:53 AM
shbox's Avatar
The difference in coil wires has nothing to do with the length. The end on the coil is different for 96-97, because they changed the coil.
What you see is an arc-not an arch.
Old Jan 12, 2010 | 07:32 AM
Paul Bell's Avatar
AKA High-Temperature Boot Sleeves.
Old Jan 12, 2010 | 10:31 AM
Gojira94's Avatar
projekt70chevelle is onto something with resistance. Electricity will of course always follow the path of least resistance. So what's downstream from the coil? Distributor, wires, plugs. Downstream from the wires? Just the plugs. Imagine how much resistance is in the shielding & insulation of those Taylor wires and has to be overcome in favor of where it's supposed to go. Not saying go and replace everything by any means, but finding the high resistance is the key (and the challenge). Even a loose plug boot can do it.
Old Jan 12, 2010 | 10:38 AM
1 Craz28's Avatar
I'm thinking of insulating with lead tubeing?
Old Jan 12, 2010 | 11:01 AM
jebcamaro's Avatar
Lead tubing?
Old Jan 12, 2010 | 01:20 PM
shbox's Avatar
Originally Posted by jebcamaro
Lead tubing?
Sigh, don't ask.
Old Jan 12, 2010 | 02:00 PM
AChotrod's Avatar
What coils are you guys using?
Old Jan 12, 2010 | 04:21 PM
1 Craz28's Avatar
I'm using stock coil which is fairly new. A MSD 6al that really lengthens the spark duration? I think I have a cylinder loading up with fuel on the drivers side. I've got some new plug wires coming too. When I drive it runs awesome, then at idle, like at a stop light or sign for a few moments, when I start to go again it gets very sluggish and I hear a "clunck" under the hood? Then if I spinn it a little it runs fine again?
Old Jan 13, 2010 | 11:00 AM
fleetmgr's Avatar
Hard to insulate something by providing a second conductor. If what you really mean is shielding, what for? Are you getting interference in your radio? That, or interference with some other electronic widget would be the only reason you'd need shielding.
Old Jan 13, 2010 | 11:10 AM
djjab57's Avatar
Unhappy
You will learn to ignore his threads in time, It shouldnt take you long
Old Jan 13, 2010 | 12:36 PM
MTBSully's Avatar
haha i just spent my entire luch break reading all of his retarded threads on here and on ls1lt1.com
thanks for the material craz28
