Spark Plug Length?
Old Jan 15, 2010 | 07:13 PM
1 Craz28's Avatar
Default Spark Plug Length?
I just recieved a set of stock AC .R45LTS6's and they actually look shorter than a compatible one. It only has 7/8th's of porcelain. What is the standard length of a spark plug? This may be the reason I am burning plug wires? I think the AC's I have in now are longer!
Old Jan 15, 2010 | 07:31 PM
LT1WS6's Avatar
hahahahah
Old Jan 15, 2010 | 07:37 PM
1 Craz28's Avatar
You laugh because you got rid of your mid-tubes a long time ago?
Old Jan 15, 2010 | 07:38 PM
1 Craz28's Avatar
I only have 3/8th's from my spark plug on number five's cylinder!
Old Jan 15, 2010 | 07:42 PM
Badazz 97 TA's Avatar
some sand paper should fix it.......
check your opti. and nice ricer wing!
Old Jan 15, 2010 | 08:02 PM
1 Craz28's Avatar
Hey man I like my wing better than the one on that new green camaro! Opti is not that old. It's holding up! Mine does not suck moisture into it like yours! I got over tens years on my last one!
Old Jan 15, 2010 | 09:02 PM
huh.....??????
i would sand down the plug with a Dremel. that should fix it. Nice ricer wing!
Old Jan 15, 2010 | 09:49 PM
1 Craz28's Avatar
I got it from JEGS! It's not RICE. Actually I noticed the tips on my new ones are slightly sanded on the tip, just to get the paint off. I don't want to change the shape, good idea though, I also thought of removing the threaded tip on the problem one. But I think these are shorter? I'll double check tomarrow.
Old Jan 15, 2010 | 10:45 PM
well i would sand it down to change the shape and make it shorter. Making it shorter will make the spark more powerful since the electricity has less stuff to go through. so start sanding away!!!
if you make it into a point on the end the electric current will build up and then create and bigger spark for more power. you can sand it down about 1/2inch safely
and yeah it is rice. Its a shopping cart wing
Old Jan 16, 2010 | 12:02 AM
1 Craz28's Avatar
Is'nt there a resistor in it somewhere? That's is a great idea though!
Old Jan 27, 2010 | 11:13 PM
airfix's Avatar
You just don't get it do you. No body wants to hear your BS, or help you with your stupid problems. So GTFO
Old Jan 27, 2010 | 11:48 PM
litch2004's Avatar
^^lmfao
