hard to turn without power steerinng?
Old Jan 19, 2010 | 01:57 PM
RamAir95TA's Avatar
Originally Posted by DarkJuggalo
all of my cars(except my 01 ws6) used manual vega steering boxes, its odd at first to get used to but on the highway/cruising around town you dont even notice it. however from a dead stop you sometimes have to use 2 hands to turn the wheel, but its really not all that bad. ive had 4 manual steering cars, and 3 manual brake cars, street cars plus its a good excuse on why the girl/wife cant drive it
I don't know about you, but I just say, "Bitch! Hands off!!"
Old Jan 19, 2010 | 04:40 PM
96blackta's Avatar
"When do I get to drive your car?"
"Eh... I kinda don't let anyone drive my car."
"But you've driven the King Ranch, Yukon, Pilot and Navigator..."
"Different... just different...."
Old Jan 19, 2010 | 04:58 PM
Racin96ss's Avatar
Originally Posted by Wicked94Z
i didn't mind mine at all until i put a spool in the car... now its a bitch
X2 here...I actually thought it steered better without the PS hooked up...LOL
Once the spool went in, it got a lot harder!
I had 245 front tires at first and they turned a lot better than the 275's did!
Old Jan 19, 2010 | 05:20 PM
ThreeHonks's Avatar
since i have skinnies up front do you think I would be ok?
Old Jan 20, 2010 | 12:14 AM
TAEnvy's Avatar
If your just trying to clean up engine bay run a little bitty, p/s pump, and a pretty billet resovoir, someone on here did it. LT1TA or L/ATA I cant remeber his screen name.
Its a blue LT1 TA
Old Jan 20, 2010 | 02:28 PM
Racin96ss's Avatar
Originally Posted by kalebm22
i am thinking about runin only the alternator on a street car and i cant make up my mind if i want to delete the power steering and keep the stock rack in the car. how many of you drive your car on weekends with no power steering and do you regret it?
I say go for it. It really cleans up the engine compartment. I'd do it all over again.
For sure with skinnies! You could run up to a 255 front without much issues
Old Jan 21, 2010 | 07:56 PM
kalebm22's Avatar
Restricted User
well i finally started tearing the power steering off and i have a bracket on the way from pcm for less. i just looped the hoses for now, i didnt know any other way to do it.
does anyone know what kind of dyno results that show how much power i would pick up?
Old Jan 24, 2010 | 07:51 PM
kalebm22's Avatar
Restricted User
anyone know?
Old Jan 25, 2010 | 07:25 PM
kalebm22's Avatar
Restricted User
ok, to finishh this off i got the pcmforless bracket with gator belt. it bolted up great and everything lined up. the car was suprisingly easier to turn than i could have imagined. but i have around 230+ pounds of weight reduction from the firewall forward so that might have made it much easier. the engine sounds much smoother and revs alot quicker. i would recomend this to anyone that can do without a/c
Old Jan 26, 2010 | 07:03 AM
ThreeHonks's Avatar
Thanks! your post is swaying me to get rid of mine now. do you think you can post a few pics of it? especially of how the looped lines look.
Old Jan 26, 2010 | 08:43 AM
MTBSully's Avatar
take the belt off and drive around a little bit and see if you like it. I wouldnt do it on a street car
Old Jan 26, 2010 | 09:02 AM
  #32
Joshiedoom's Avatar
I think im in the same boat
Old Jan 26, 2010 | 09:07 AM
  #33
ThreeHonks's Avatar
then posts like this make me sway back and forth on the subject I dont really drive the car too much on the street, and if I do, its not to go get groceries
Old Jan 26, 2010 | 09:40 AM
  #34
MTBSully's Avatar
seriously. take the belt off and rive around the neighborhood (not too far since the alternator wont be charging the battery). It will be exactly the same as a power steering delete. We can sit around here all day and tell you about what WE think or you can go and try it for yourself.
Old Jan 26, 2010 | 01:28 PM
  #35
kalebm22's Avatar
Restricted User
i will try and get some pics of it all. but right now the lines arnt looped permanantly yet cause i wasnt sure if i was goin to like it without powersteering so i left the lines long so i could put it back on if i wanted. i also drive my car 6 days a week as a dd and very rarely sees track time. but i can also tell you it is easier to turn without the power steering and a/c stuff on the car so just taking the belt off isnt as accurate as it seems. it will give you an idea though. i am 135 pounds and i can still drive with one arm as long as i am goin 2mph or faster. from a dead stop it takes two hands but i havnt been in a spot where i actually needed to use both hands yet. i also have 255/40 17s upfront but i put about 45psi in them. that being saidd if you have skinneys i dont think you will have any trouble turning at all.
Old Jan 26, 2010 | 01:38 PM
  #36
RamAir95TA's Avatar
For those reading this, I would not loop the PS lines. The outlet puts out some SERIOUS pressure (upwards of 700+ psi). It will likely blow off.
Old Jan 26, 2010 | 02:14 PM
  #37
thatguy383's Avatar
power steering is worth the weight on a street car. always.
Old Jan 26, 2010 | 05:12 PM
  #38
ThreeHonks's Avatar
So what would you do instead? i know a manual rack is the right way, but do you have any good recommendation instead of looping the lines?
Old Jan 27, 2010 | 12:54 AM
  #39
camaroz28383's Avatar
are we talking looping the lines on the rack or looping the lines on the pump? I see the pump putting out 700+psi but the rack putting out 700+psi...
Old Jan 27, 2010 | 12:58 AM
  #40
kalebm22's Avatar
Restricted User
well idk what he means on that but i looped the lines on the rack and completely removed the pwr steering. i only got about 6 miles of driving without it and my engine spun a bearing i guess it revs alot faster than them stock bearings could handle haha. so i cant say wether or not it will hold up but it didnt leak a drop in the 6 miles that i drove it.
