Security light on, car not start.
Car wouldnt start(BUT WOULD CRANK), I found that my OPTI finally went out. I replaced it and took it for a test drive, everything was good with it, came back home and let it sit for 30-45 mins, Then I went back to pull into garage and NOTHING..
I turn the key and the SECURITY light flashes NON STOP and car will not start.
Its as if Im getting in to start and NOT pushing in the clutch.
I replaced my Key and it did not fix it..
Ive disconnected battery and that did not help..
What else should I do?
Thanks
Kris
Thanks
Kris
I pulled the panel under the steering wheel off and found the ignition wire(two small white wires with orange loom NEXT to the AIR BAG wires)
I cut the wire on the TDM side of the connection and put 2370 ohm resistors on it and she fired right up!
SOOOOO My lock cylinder went out...
Kris
Kris
