tps voltage
Old Jan 21, 2010 | 02:18 PM
96Formula6spd's Avatar
Default tps voltage
Hey guys been looking for awhile and cant find what the tps voltage needs to be set at. Looking for a 94-97 lt1. Thanks
Old Jan 21, 2010 | 02:28 PM
stevo9389's Avatar
somewhere close to .6 volts with the blades closed if i recall correctly. with my 58mm TB and stock TPS it sits around .7-.75 but was tuned for it cause i didnt want to notch the sensor.
Old Jan 21, 2010 | 03:45 PM
RamAir95TA's Avatar
Anywhere from .2v to .9v is fine with the throttle closed. The PCM will prorate the voltage from there.
Old Jan 21, 2010 | 06:13 PM
StealthFormula's Avatar
I always set mine to .67 volts like it says here:
http://www.golenengineservice.com/html/tps.html
Old Jan 21, 2010 | 06:40 PM
thanks
