O2 sensor codes after header instal?
Old Jan 21, 2010 | 04:49 PM
jasonz28camaro's Avatar
Default O2 sensor codes after header instal?
I put lt headers on my 96 ss 3 months ago and it ran fine for 2 months. it's throwing slow response codes now, I have replaced the o2 sensors with brand new delco ones. Any suggestions?
Old Jan 21, 2010 | 04:52 PM
RamAir95TA's Avatar
Were the headers ceramic coated?
And when did you replace the O2s, during the header install or recently (you're a little unclear)? Did you delete the rear sensors too?
Old Jan 21, 2010 | 05:11 PM
FASHOOTER's Avatar
Did you get a tune?
Old Jan 21, 2010 | 06:56 PM
96lt1m6's Avatar
110% agreed....
if you have changed o2 sensors too soon they will go bad from the coating burning off!
i cheat when before installing new COATED headers,i spray alcohol into each tube and light them on fire to speed up the process then reinstal the old O2s for a while....
Old Jan 21, 2010 | 07:06 PM
Sorry I should have given more info. The headers were used so the coating is stuck, and i didn't have to replace them until it started to throw codes 2 months later. I used the sensors that were on the headers when I bought them bc I didn't want to mess up new ones. I never got around to changing them until it threw the codes. I bought delco o2s and everything was fixed for only 5 days when it started again. Madz28 tuned the car and deleted o2s, egr,air and his power tune. I spoke to ion and he said the computer might be bad. Do they just go out?
Old Jan 21, 2010 | 07:07 PM
They are jethot headers.
Old Jan 22, 2010 | 01:30 PM
Z28_LT1's Avatar
i didn't know about the coating sensor thing and i used them anyway. nothing happened....
