help
Old Jan 21, 2010 | 06:52 PM
BallerCamaro21's Avatar
Default help
hey my check engine light came on and the code is p0441. What is the code and how do i fix it.. help please
Old Jan 22, 2010 | 01:56 AM
94CamaroZ28SS's Avatar
P0441 Evaporative Emission Control System Incorrect Purge Flow
Symptoms Likely, no symptoms will be discernible to the driver, other than the illuminated Check Engine Light.
Causes
A code P0441 could mean one or more of the following has happened:
Bad vacuum switch
Broken or damaged EVAP line or canister
Open in PCM purge command circuit
Open or short in Voltage feed circuit to Purge Solenoid
Faulty purge solenoid
Restriction in EVAP solenoid, line or canister
Corrosion or resistance in purge connector
Bad PCM
