ok can someone help me with some air flow ideas?
So I bought a 95 TA that is Super charged. I am looking to put a 2.93 pulley on it and bump the cam up. The current cam is .524 I was looking around .594. Although it is stock heads worked over to .200 .160 with a LT4 intake that I dont know if its been worked over. The car def needs to be tuned and I am in the current state of resealing the V1 head unit. I was wondering also if I do change the pulley out do I need to replace the bearing for a higher RPM rate? I am about to get a taz return <finally the gov helps the car man> So I will be looking to buy these parts soon. So someone please help
OK SO WHAT I AM LOOKING AT IS WHAT HEADS SHOULD I LOOK AT? WILL I HAVE A PISTON VALVE CLEARENCE ISSUE? WHAT ABOUT THE INTAKE WILL THE INTAKE SUPPORT THAT KIND OF FLOW?
