What's needed to go 10.50's full weight and all accesories?
Hey what's up guys, I'm trying to figure out what's needed to go 10.50's with a full weight (3800 with driver but no cage, yet) full accessories m6 LTx poweered f-body?
Well I've got the built motor part done (fully forged, splayed 4 bolt mains 11.8:1 cr 383, LE3 heads, ported intake, 847 cam, EWP, 58mm tb and LS1 lid, EFI Connections ignition and 42# racetronics injectors) stage 2 built t56, billet lw flywheel and 6 puck clutch, S60 rear with relocation brackets. SLP weld in sfc, UMI k-frame and upper/lower a-arms, J&M lcas and adj phb, UMI adj TA and phb relocation kit Strano springs and Bilsteins and a 3" true dual exhaust. I plan on getting nitrous at tax time and running a 150 - 200 shot.
I should have stated that this car is my daily driver that's why I'm keeping all of the accessories and that's why I have the springs/shocks I have. At some point I may try a more drag oriented spring/shock package if I can't get the car to 60 ft. However I want to see what it can do with this suspension first before I make changes. As for wheels and tires right now I have 17" ZR1s with Nitto 555r tires and MT 295x40x17 drag radials but I'm also have 13" front brakes so I need a 17x4 front wheel and I haven't found anything yet.
Thanks guys, I haven't finished installing the new engine and ignition yet but once I do I'll get it dyno tuned so I'll have an idea of a starting point. But I figure my combo na with a good dyno tune should be good for 420 - 450 rwhp which should be good for mid to low 11's with good traction. Then I don't see why a 150 shot wouldn't get me to a 10.50, is my math off?
Hey RamAir what heads/cam are you running to get 11.1 @ 122 na and why don't you think my le3 heads/847 cam can run close to your na times?
I just want to point out a couple things that I didn't see that I would make sure to have on the car, sorry if I missed them in your post. If your running a full length T/A mounted to the trans I would suggest buying a relocation kit to mount it off the trans mount instead. That will prevent you from tearing the tail shaft off. Although not necessarily ideal for a daily driver, an anti-sway bar will be almost mandatory to get the car to launch straight and consistently.
Possibley if everything works out right and suspension is set up right. Just saying with it being 6spd that it may take a little more, but there are some fast 6spds out there that have everything working right! Just get it done run it and let us know how it does.
