rocker adjustment weirdness
Old Jan 24, 2010 | 10:54 AM
RamAir95TA's Avatar
:facepalm:
Old Jan 24, 2010 | 12:30 PM
ADM's Avatar
ADM
I did it the exhaust starts to open, adjust intake and then intake 1/2 turn past maximum lift, adjust exhaust.
Fired right up!
Old Jan 24, 2010 | 01:42 PM
camaroz28383's Avatar
Fired right up!
but you didn't have lifters from satin
Originally Posted by RamAir95TA
:facepalm:
yea tell me about it
Old Jan 24, 2010 | 06:42 PM
SS RRR's Avatar
Village Troll
Originally Posted by camaroz28383
Its like under the plunger filled up with to much oil and would not compress, weirdest thing that I've seen never had a problem with lifters that required me to drain the oil out of them
Oh Jesus...
Old Jan 24, 2010 | 07:38 PM
Originally Posted by SS RRR
Oh Jesus...
elaborate, please share some of your wealth of knowledge
Old Jan 24, 2010 | 08:12 PM
SS RRR's Avatar
Village Troll
What kind of lifters are these? How do they fit into the lifter bores? Is there any resistance when put into the lifter bores?
Old Jan 24, 2010 | 08:27 PM
they are supposed to be gm replacements not ls7s but from before they switched over to those as replacment lifters for lt1s they were in my buddies garage (in a ziploc) for a while never used I dont think he would lie to me about what they were, not like he was trying to pass them off as something expensive.
they fit fine when you drop them in the bore they slide down nice and easy on there own, dont bind in any way.
Old Jan 25, 2010 | 02:54 PM
SS RRR's Avatar
Village Troll
I got nothin'. Best of luck.
Old Jan 26, 2010 | 12:31 AM
I'm as baffled as you
I just hope these things work fine once the car fires they are all adjusted properly right now but my luck they'll all explode on fire up
Old Jan 26, 2010 | 01:18 AM
RamAir95TA's Avatar
Why wouldn't you just invest in a set of LS7s so you aren't guessing? Eliminate that part of the equation.
Old Jan 26, 2010 | 01:20 AM
I'm poor plus Ls7's mean new pushrods and I def dont have money for those right now either
Old Jan 26, 2010 | 01:35 AM
  #32
ADM's Avatar
ADM
So lets get this straight.
You invested a lot into building a 383, and now your skipping on the pushrods?
Old Jan 26, 2010 | 01:39 AM
  #33
nooooo I have old GM lifters but there being all retarded
Old Jan 26, 2010 | 10:42 AM
  #34
RamAir95TA's Avatar
Unreal. If I were in your shoes, I'd stop ******* with it and GET THE RIGHT PARTS. Whether you have the money in a day, a week, or a month, it's something you need to do.
Old Jan 26, 2010 | 11:06 AM
  #35
ADM's Avatar
ADM
If that doesn't set him straight, I don't know what will!
Old Jan 26, 2010 | 01:45 PM
  #36
first of all they are the right ******* parts genuine GM!!! second one of my buddies who goes to UTI is in the build a sbc and dyno it part of the curriculum right now and I gave him the lifters to run in the motor to see if they work I will know by the end of the day weather or not there good so
Old Jan 26, 2010 | 02:01 PM
  #37
RamAir95TA's Avatar
Yep! They sound like the exact lifters you need! Lifters in Satan's garage in a ziploc bag. Awesome!
So you're going to take Satan's lifters (which were in a garage in a ziploc bag) that he pawned off to you, installed in your motor where you proceeded to continually screw up the preload, disassembled HALF of them only to find nothing (too much oil in the lifters? ), then put them allll back together again, and now your buddy who is in school at UTI (I should note that he is in the 'learning' phase, not the "graduation" phase), and he's going to "test" them on a completely different motor, then give them back to you after they're magically fixed, all because you don't see the need to invest in a set of OEM-replacement lifters.
Sounds like you got it all figured out then.
L. O. L.
Old Jan 26, 2010 | 02:25 PM
  #38
ahhh f off
this is the way I see it if hes still "learning" whats the worst case he says there f' up, if he does everything right and they dont work right or he does it wrong and they dont work right well then I'll end up getting new ones but if he does everything right and they work corectly well then there good to go and I wouldn't say hes in the learning phase he does have a 600 horse 3rd gen with a 350 in it that he built and has built a bunch more motors so I think he gets the idea... so what there being tested in a different motor the cam still gonna go round and round and make the lifter go up and down up and down
Old Jan 26, 2010 | 02:33 PM
  #39
RamAir95TA's Avatar
ahhh f off
This is the LOLiest thing I've read in awhile.
Good luck man.
Old Jan 26, 2010 | 02:41 PM
  #40
ADM's Avatar
ADM
I vote, best thread ever.
