How much nitrous can an LT1 flow?
Old Jan 25, 2010 | 01:29 PM
bowtienut's Avatar
I think we have a few different definitions of "stock" LT1 floating around in people's heads here! There are not many 400 hp stock LT1's!
With stock heads and stock cam, you reach an exhaust flow limitation long before these 200-275 hp hits being thrown out there.
Old Jan 25, 2010 | 01:35 PM
AChotrod's Avatar
I agree^^^ Just not sure what the actual number is.
Old Jan 25, 2010 | 01:38 PM
kinglt-1's Avatar
Im just reporting what I have seen first hand. Im not saying to go out and throw a 200+ shot on your stock lt1, but guys do it and get away with it. I was not refering that stock lt1's make 400hp, it was just a number for comparison. A stock lt1 typically run around the 300hp at the crank, so in theory a 150 shot would be about tops...
Old Jan 25, 2010 | 06:34 PM
9730thSS's Avatar
I'm up at Denver like the original poster is(ok; ie colorado sprgs) and granted not on a stock top end, but I shove unmetered amount of fuel and nitrious into the motor. I do know the solinoids are made to flow 300 hp, but I've got it set up for direct port inside the manifold at each intake port. Just to give you an idea I can only get 6-7 runs out a 15lb bottle. I run this all on a stock bottom end, and fueling is very important when running this much nitrious or yes you will have a melt down.....
Old Jan 25, 2010 | 06:57 PM
pyro719's Avatar
Yup this is what I'm talking about. Tou can only stuff so much air/fuel/nitrous into a cylinder before it starts "backing up" into the intake port and intake manifold. I'm not saying I want to stuff a 300 shot on my car I was just wondering how much you could stuff into the cylinder? wor what its worth I I'm doing a stand alone fuel system and using a nitrous outlet plate and plan on spraying a 200 shot.
Originally Posted by moehorsepower
I think what he is trying to say in the term "Back up" Is like an incidence we had years ago on a carbed small block inhaling a healthy dose of the gas. on the dyno at wot I saw nitrous coming back out of the carb, telling me either it was too much for the set up, ignition ect. Maybe this is what he is saying by back up??
Old Jan 26, 2010 | 12:23 PM
OutlawZ's Avatar
A 200 shot is about the limit of what is safe on stock hyperutectic pistons with stock ring gaps from the factory.... regardless of heads,cam and what not..... I see what the OP is saying but the fact is you won't approach the "filling up the cylinder" limit with fuel/air/nitrous without blowing it up. A nitrous or naturally aspirated motor is not very efficient when it comes to inhaling it's own air..... the cylinder is probably only half as full as it could be even at best.... which is why forced induction makes so much power...... cause now you are approaching much better efficiency breathing.... The engine is an air pump. make it pump air better and you will increase power when you increase fuel accordingly. But nitrous and NA motors LT1's included don't have really great lungs stock.....
going back to the 200 shot limit.
that much cylinder pressure is going to be alot for the stock pistons, rings, rod bolts, etc to handle for many passes.... you might get 5 or you might get 50.... but it will be on borrowed time....
You could run 150 shots all day most likely. A 200 shot is going past or right up against the 50% rule.. (if it's bone stock a 150 shot would be half 300.... If it's H&C a 200 shot would be about half of 400hp).... PURPOSE built nitrous motors can exceed the 50% rule with proper ring gaps and forged pistons, upgraded rod bolts, 4 bolt splayed mains, etc....
Old Jan 26, 2010 | 12:29 PM
bowtienut's Avatar
I don't buy that 50% rule!
Bone stock, I'd shoot a 150 shot till the cows come home.
I sure as heck wouldn't throw a 200 hit on the motor I'm running now - H/C putting down 425 rw. In fact, I think it would be short-lived with even a 150 shot. 425 SAE is about 525 at the crank, and that's a lot of heat going into the pistons and rings even without any nitrous. I sure would love it if somebody could convice me that I'd be safe with a 150 hit on it.........heck, I'd be gunning for low 10's in this big sled!
Old Jan 26, 2010 | 12:32 PM
kinglt-1's Avatar
Good post outlaw, this was exactly my point aswell!
Old Jan 26, 2010 | 12:36 PM
OutlawZ's Avatar
Well here's the caveat to that rule.... the 50% RULE per se is a guideline as far as i'm concerned.... and it ASSUMES that your nitrous tuneup is dead on..... well how do you get to a good nitrous tuneup? Trial and error mostly. And mistakes will be costly.... So if you hover around the 50% you are risking that your tuneup is not that great. And if it's not great you have a greater risk of hurting something.... So most ppl will call it at a 150 shot which is the right idea.....
How many dudes you know of with stock LT1's or mildly modified LT1's that are spraying 200 shots that kill their cars at the finish line and pull their plugs to read them??? Probably not many....
Which shows me they don't really give a **** what their tuneup looks like and they just go by the jet recommendations from NOS, or NX, etc..... The same ppl who don't give a **** if your motor blows up running their ****..... When I ran a 150 shot I was plug reading illiterate.... Surprised my **** lasted as long as it did back then in like 1997...
Thanks..... been doing the nitrous thing for awhile and theres alot of good info out there and alot of misinformation as well....
Old Jan 26, 2010 | 12:43 PM
kinglt-1's Avatar
Obviously you wouldnt put a 200 on the motor your running now. Your already pushing the limits of what the stock shortblock can handle. Power is power no matter what it takes to get there, the parts don;t care, they are going to fail at some point... IN GENERAL YOU CAN SPRAY 50% OF THE MOTORS NA POWER ASLONG AS THE PARTS ARE BUILT FOR THAT SPECIFIC POWER LEVEL YOU WILL BE PUSHING LOL.
Old Jan 26, 2010 | 12:56 PM
bowtienut's Avatar
Thanks!.....for clarifying where I was trying to go with my comments!
I'll grant that the 50% rule seems to apply well from a flow standpoint through the engine, kinda the discussion we were in when this thread started.
Old Jan 26, 2010 | 01:04 PM
  #32
nickp's Avatar
[QUOTE=OutlawZ;12803492]
i do . and its a good thing because my **** gets pretty lean on a 150 w/a 255lph fuel pump, at the kits suggested jetting. i would have fucked something up by now for sure, if i didnt notice that imeadiatly.
Old Jan 26, 2010 | 01:28 PM
  #33
OutlawZ's Avatar
You are in the "smart" minority.
Alot of ppl will use a wideband but a wideband is reading an average of all cylinders..... so if one is super fat and one is super lean they cancel each other out...
won't stop the piston from melting however..... read them plugs people, read them plugs...
