oxygen sensors
Old Jan 24, 2010 | 02:53 PM
slp96ss's Avatar
Default oxygen sensors
Seeing how my car is covered and it's freezing out, maybe someone can help me. How many oxygen sensors does my 96 SS have? Also, does anyone know why I would get two codes saying my car is running too lean? I have a loudmouth I catback and slp cold air kit. What would cause a car to run too lean? Afterall, these cars were made running rich weren't they? Thanks for any help.
Old Jan 24, 2010 | 02:58 PM
pillarpod's Avatar
i'm pretty sure you have 2 O2 sensors. one on eacher header
Old Jan 24, 2010 | 02:59 PM
pillarpod's Avatar
i got that code saying it was running lean, i replace both my o2 sensors and it fixed the problem
Old Jan 24, 2010 | 03:00 PM
slp96ss's Avatar
I thought there were four? Two up front on the manifolds, and two by the cats?
Old Jan 24, 2010 | 03:05 PM
pillarpod's Avatar
for what i know they didn't start doing that until the '98 car, unless you have the Calif. Car then you have 4.
Old Jan 24, 2010 | 05:43 PM
slp96ss's Avatar
anyone else with anything?
Old Jan 24, 2010 | 05:56 PM
Spartan7's Avatar
Wrong. All OBD2 cars (started in 96) have 4 O2 sensors. 2 pre-cat, and 2 after-cat. All 95 cars sold in California also have 4 O2's, and the dual cats as well.
Old Jan 24, 2010 | 07:01 PM
slp96ss's Avatar
ok that's what i thought. i've seen hundreds of different kinds online. can someone get me a link to all 4 of them, and a good brand as well? that would be awesome. too many to choose from, i want to get something good.
Old Jan 24, 2010 | 09:22 PM
pillarpod's Avatar
bosch is a great brand
Old Jan 24, 2010 | 09:41 PM
Badazz 97 TA's Avatar
please stop posting retard. You dont know what your talking about........
go ac-delco or Denso. no other
Old Jan 24, 2010 | 10:27 PM
blkcamaro_z28's Avatar
recommend AC Delco for sure. DO NOT get bosch none of there stuff works well with LT1's.
Old Jan 25, 2010 | 07:48 AM
koolaid_kid's Avatar
You have 4 sensors, 2 on each side. The front ones are used by the PCM for adjusting fuel trims. The back 2 are used by the PCM to monitor the cat efficiency.
Which codes are you getting? Listing them may help figure out what is going on before you start throwing parts at it.
Also, it would greatly help if you did some real-time data logging, even a wideband in the tailpipe. You can use these tools to monitor the output of the sensors, and the wideband to see if you really are running too lean.
I use Autotap and an LM-1 to do this. I checked out a friend's Toyota this way, and figured out his injectors were at fault, plus his front sensor was lazy. He sent the injectors off to FIC, replaced his front sensor, and is extremely happy now.
Old Jan 25, 2010 | 10:59 AM
pillarpod's Avatar
I have always used them and i've never had a problem with them
Old Jan 27, 2010 | 04:22 PM
slp96ss's Avatar
so far I've gotten three codes to come up, at it's worst there were a total of five so I'm waiting on two more to pop up. what i have so far is oxygen sensor heater circuit bank 2 sensor 2, bank 1 too lean, and bank 2 too lean.
Old Jan 27, 2010 | 04:39 PM
SoxXpupPeT's Avatar
you have OBS II and thus, you have 4 o2 sensors.
Old Jan 27, 2010 | 04:46 PM
WARDOG's Avatar
IM with this guy, get some a/c delco oxygen sensors. I dont trust bosch sensors, i had terrible problems with them and so have many others around here. Good luck
Old Jan 27, 2010 | 04:52 PM
djjab57's Avatar
gmpartsdirect.com is the best place to get them, but there might be a cheaper place. Do a search as we have talked about this several times
