P1371 code DI low resulution
Old Jan 25, 2010 | 09:36 PM
ladybird's Avatar
Cool P1371 code DI low resulution
I did a little research and it could be either the crank sensor mounted in the timing cover or the optic sensor mounted in the the opti. Car was running fine I just happened to notice the light and I scanned it. Car is not driven since its January I just happened to start it.
Old Jan 25, 2010 | 09:47 PM
shbox's Avatar
P1371 Distributor Ignition (DI) low resolution circuit
Opti or opti harness. It's not the crank sensor.
Old Jan 25, 2010 | 09:49 PM
camar0corey's Avatar
Does it take longer to start? Last time I saw a low resolution code was on the LT1 my Mom owned, car took forever to crank, but it ran alright. It was the opti in her case.
Old Feb 4, 2010 | 06:11 PM
ladybird's Avatar
Cool
No actually started fine. I was surprised the light came on. Where can I get a new opti harness? I have replaced the opti before twice. Before I pony up the bucks I would like to replace the harness. At least if its not the problem it will be new.
Old Feb 4, 2010 | 07:21 PM
jaysz2893's Avatar
ebay has harnesses for about 50 bucks.
Old Feb 4, 2010 | 08:40 PM
Green3spd's Avatar
I got my last one for $35 shipped... But the damn clip that holds it in the opti broke the first time I tried to pull it out...
Kris
